I often need to inspect line feutures I have drawn some second before.
How can I avoid to insert by accident a new (unwanted) vertex on that line when clicking on it ?
regards
Tibor
regards
Tibor
Hi Tibor,
To select a polyline without having a new vertex, you need to be in selection mode.
This can be enabled by clicking on Simple Selection (or simply type S).
You might need to first click somewhere else.
Let me know if this helps.
Daniele
Once a polyline is selected, it seems that clicking the line again will insert a new vertex, even if we’re still in Simple Selection mode, right?
I think that locking the layer that the polyline is on will not allow you to add more vertices. @tibor.vari this might be the solution you’re looking for.
As long as a polyline is selected, a new click on it will create a new vertex. To select the line again, you need to first select something else in order to unselect the line.
In any case, this will bring you to the same state where you are as soon as you complete a line with the right click.
![Polyline Selection.mp4 [video-to-gif output image]](https://global.discourse-cdn.com/pix4d/original/2X/8/8f2f011755f98a17c81200e847d26675aeed60d6.gif)
If you want to inspect the vertices, just press S after you complete the line, and you can inspect the vertices:
![point inspection.mp4 [video-to-gif output image]](https://global.discourse-cdn.com/pix4d/original/2X/7/756d3b13a1e5e379d24730ec5ffd0285e8e31814.gif)
Daniele
