Dear people, I have been processing the same data-set, one local with Pix4D mapper and one via Pix4D cloud processing. The matching of the cloud processing is much, much better than the local processing. What could be the cause, or is the cloud engine much better in matching ect.? I’v uploaded the local results to cloud.
Cloud
Local
Hi, if you’ve setup the PIX4Dcloud project through the PIX4Dcloud interface, then you have a different processing pipeline that is selected than the one in PIX4Dmapper. The processing pipeline on PIX4Dcloud will be more similar to what you can find in PIX4Dmatic. If you’ve uploaded your project to PIX4Dcloud through the PIX4Dmapper interface (cloud upload), then it should be more consistent between both.
