Could someone tell me the difference between Pix4dcloud and Pix4dmapper? Are there fewer features in the cloud version? Is there less accuracy and control over the data?
Hi Andrew,
PIX4Dmapper is a desktop solution to process your projects while PIX4Dcloud is a cloud solution to process, store and also share the results of your projects.
There are also differences in terms of inputs and outputs, also about features, and workflow… and with both solutions, you can get accurate results.
Working with PIX4Dmapper or PIX4Dcloud depends more on your project needs so I recommend you to contact our sales team so they can assist you with more information according to your specific needs: Talk to sales
Cheers
