A relative smal map is stuck in processing online i can’t see a problem of any type.
the processing time was estimated on 1 hour it is now procssing for 5 hours?
@Kapil_Khanal I also have a project that is stuck processing. Estimate was 1 hour, it has now been several days. I am frightened to delete it because i don’t know if i will be able to re-upload it after that, could you please let me know if deleting would help?
this has happened again, albeit slightly differently. I now have a project that is returning just “error”, unspecified. No outputs available. There were 339 input images. I checked the FAQ on what to do, but nothing seemed relevant. Log text is as follows:
“[2022-09-23 08:44:13 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] Started skyseg with parameters profile PIX4Dcatch.
[2022-09-23 08:44:13 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] Process memory usage before sky-segmentation is 127 MBs.
[2022-09-23 08:44:13 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] image_parallelism: 18
[2022-09-23 08:44:13 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] nn_inference.n_processes: 9
[2022-09-23 08:44:13 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] nn_inference.n_threads: 4
[2022-09-23 08:44:14 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] Launched 9 CPU inference processes, each with n_threads=4
[2022-09-23 08:44:14 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] About to run surface coverage estimation on 339 images with portrait orientation.
[2022-09-23 08:44:14 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] nn_inference_size: [224, 338]
[2022-09-23 08:44:17 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] Ran inference for 18 images with batch_size=1 on CPU (3.1239376068115234 s)
[2022-09-23 08:44:21 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] Ran inference for 18 images with batch_size=1 on CPU (2.6986773014068604 s)
[2022-09-23 08:44:24 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] Ran inference for 18 images with batch_size=1 on CPU (2.6819748878479004 s)
[2022-09-23 08:44:27 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] Ran inference for 18 images with batch_size=1 on CPU (2.6890718936920166 s)
[2022-09-23 08:44:30 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] Ran inference for 18 images with batch_size=1 on CPU (2.613006830215454 s)
[2022-09-23 08:44:33 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] Ran inference for 18 images with batch_size=1 on CPU (2.6132028102874756 s)
[2022-09-23 08:44:36 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] Ran inference for 18 images with batch_size=1 on CPU (2.652808427810669 s)
[2022-09-23 08:44:39 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] Ran inference for 18 images with batch_size=1 on CPU (2.720184564590454 s)
[2022-09-23 08:44:42 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] Ran inference for 18 images with batch_size=1 on CPU (2.645749568939209 s)
[2022-09-23 08:44:45 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] Ran inference for 18 images with batch_size=1 on CPU (2.6483447551727295 s)
[2022-09-23 08:44:48 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] Ran inference for 18 images with batch_size=1 on CPU (2.699521780014038 s)
[2022-09-23 08:44:52 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] Ran inference for 18 images with batch_size=1 on CPU (2.7288191318511963 s)
[2022-09-23 08:44:55 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] Ran inference for 18 images with batch_size=1 on CPU (2.6905951499938965 s)
[2022-09-23 08:44:58 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] Ran inference for 18 images with batch_size=1 on CPU (2.6908118724823 s)
[2022-09-23 08:45:01 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] Ran inference for 18 images with batch_size=1 on CPU (2.723235845565796 s)
[2022-09-23 08:45:04 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] Ran inference for 18 images with batch_size=1 on CPU (2.6637091636657715 s)
[2022-09-23 08:45:07 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] Ran inference for 18 images with batch_size=1 on CPU (2.690924882888794 s)
[2022-09-23 08:45:10 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] Ran inference for 18 images with batch_size=1 on CPU (2.799542188644409 s)
[2022-09-23 08:45:13 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] Ran inference for 15 images with batch_size=1 on CPU (2.459815263748169 s)
[2022-09-23 08:45:13 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] Moving on to fine-grained [‘sky’] segmentation for 45 images out of 339.
[2022-09-23 08:45:13 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] image_parallelism: 18
[2022-09-23 08:45:13 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] nn_inference.n_processes: 9
[2022-09-23 08:45:13 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] nn_inference.n_threads: 4
[2022-09-23 08:45:14 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] Launched 9 CPU inference processes, each with n_threads=4
[2022-09-23 08:45:14 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] About to run segmentation on 45 images with portrait orientation.
[2022-09-23 08:45:14 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] image_loading_size: [681, 1025]
[2022-09-23 08:45:14 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] nn_inference_size: [681, 1025]
[2022-09-23 08:45:14 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] crf_inference_size: [681, 1025]
[2022-09-23 08:45:43 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] Ran inference for 18 images with batch_size=1 on CPU (28.372987031936646 s)
[2022-09-23 08:46:16 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] Ran inference for 18 images with batch_size=1 on CPU (28.56951141357422 s)
[2022-09-23 08:46:34 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] Ran inference for 9 images with batch_size=1 on CPU (14.478548049926758 s)
[2022-09-23 08:46:38 +0000][pix4dvortex.log:29][INFO] [Sky-segmentation] Process memory usage after sky-segmentation is 237 MBs.”
Thank you for reporting this. We are aware of this behavior and are working on a permanent fix.
Currently, this issue seems to appear randomly. We have rerun the processing for this project, and I can see that it has been successful.
As we work on solving this issue, please continue to report when you receive such errors, and we can reprocess from our end. We understand this is not ideal, but we appreciate your patience and pardon the inconvenience.
I just signed up for trial, and i have 110 credits, it says processing and it is stuck…i accidentlally uploaded 4 images at the end when the drone was returning home, does it screw up the processing?
