Clip DTM to part of the point cloud
I only want a DTM for a certain part of the point cloud and even though i have moved all of the unwanted data to the point group ‘Disabled’ when i produced the contours from the DTM they still cover the entire point cloud. Surely there is a way to clip part of the cloud and just generate a DTM and contours for this section?
Hi Matt,
Did you have a look at this https://community.pix4d.com/t/6705-DTM-and-Contours-remain-the-same-despite-having-modified-the-Densified-Point-Cloud?
Let us know if this helps.
I have done exactly what you have directed me too. I have moved all unwanted points to ‘disabled’ then regenerated the DTM and re-exported the contour lines. The contour lines still cover the entire point cloud before it was edited, I need to limit the generation of the DTM to include just the points not in the disabled group.
Hi Matt,
That should not happen. Can you write a support ticket to us so that we can investigate in more details? Thank you.
