Buen dia, según tengo entendido la app para android no permite retomar el vuelo cuando se produce un cambio de baterias en un vuelo doble malla.
Quisiera consultar entonces cual es el procedimiento recomendado por pix4d cuando necesito cubrir un area grande que no es posible cubrirlo con una bateria en el caso de doble grilla.
Por otra parte quisiera saber si es posible cubrir areas que no necesariamente sean rectangulares.
Saludos,
Siego
The behavior you are describing can’t be replicated on our side and has not been reported to us so far. I would suggest you go through all the basic checks and troubleshooting steps as it will solve most of the issues that can be encountered if properly followed. I would also recommend you to go through our support article on Multi-battery / How to operate multi-battery flights.
According to the article Multi-battery / How to operate multi-battery flights is NOT possible to change the battery in a double grid mission using Android. However is possible in iOS or a simple grid using Android.
Is Pix4d working in a solution for android and double grid mission? Or have another solution or recommendation?
Thank you
The multi-battery mission doesn’t work on a double grid mission using the android device. At this moment, we don’t have any plans to implement this feature. I would suggest doing the two single grid missions by changing the angle of the flight line.
