The mission will not continue after the first battery flight.
It will not resume - all check marks go green except for the camera - an hour glass is there will not green check
Hello there, I would highly recommend going through the below support article step by step and make sure that you are following all the steps
If you are not able to fix the above issue, you might consider planning several missions that do not exceed one battery lifetime. We have a feature on the android version for mapping larger areas. For more information, visit the below support article,
