I am a survey technician who utilizes a phantom 4 pro to perform mapping of material stock pile locations.
I have recently been witnessing datasets that are coming back with a large change between initial and optimized camera parameters 5-6%. These flights do take place in areas with vertical relief as they are at stockpile locations, but the materials are homogenous (Sand, Pellets, etc). I am also having issues getting the ATPs necessary to provide full accurate coverage from these flights.
I have seen documentation online that states to calibrate your camera once a year (to come up with a new camera set of parameters), and that you should fly flights at 100 and 175 feet, each in nadir and at 30 degree oblique and run a flight in square pattern around perimeter of a high detailed building with vertical features. The articles I have come across do not state what to do with this data once captured.
Question 1: Should the camera calibration flights be run through pix4D (All at once) and save a camera model of the optimized camera upon completion of step one? Does PIX4D have a recommended process/workflow for this?
Question 2: I note that the Initial processing recommends processing Custom:1/2 Image Scale for homogenous surfaces. However, it does not state how much accuracy is lost by doing so? Does PIX4D have estimates of this?
Question 3: If I am having issues getting enough ATPs from homogenous surfaces, should I be adjusting my flight height higher or lower (or) increasing overlap? I am performing flights at 200-300 feet currently.
