Bluetooth remote trigger
Is it possible to implement start and pause capture via Bluetooth camera shutter remote as this will greatly increase the speed and accuracy of high pole top captures?
Hi ezearo,
Welcome to the community!
This is a great suggestion, and one we have looked into as well. The main issue currently, is that there is no standard between triggers and each manufacturer has a different solution/method. We will continue to look into a solution here should anything change.
Did you have a particular trigger in mind that you would want to use?
Jon
