Good morning from Texas. I have a project coming up that I am thinking about purchasing Catch for use with my Emlid RX and was curious if there was a way to manually trigger images instead of auto-capture? Even turned down auto-capture is wasteful and is not always easy to control which images it is taking in certain environments when you are trying to maintain a Fixed solution. The project though requires a single RTK-tagged image of each object. Is this possible? I asked the bot and it recommended pausing capture and triggering manually but I have yet to find a way to do that with the iPhone 14 Pro. Thank you.
Hello ADMGeo,
Thanks for your question. Unfortunately, Catch doesn’t currently support manual single-image capture. However, you can adjust the capture settings, such as overlap and quality, to better suit your needs. Lowering the overlap, for example, might help reduce unnecessary captures while still ensuring coverage.
Let me know if you’d like assistance fine-tuning these settings for your project!
