I make large areas and i would like to know, if link is broken between receiver and drone and the battery gets low, does it return to Home or it lands where is it immediately?
I would like to return to home if battery is low and link is broken. Is that possible?
" Battery : As the battery lifetime depends on multiple factors such as wind, altitude, temperature, etc., it is impossible to predict the lifetime of the battery. If the app is connected to the drone and the battery is under 20%, the drone flies home. If the connection to the drone is broken and the battery is under 15%, the drone lands where it is. Manual control might be required at that stage."
I think the best would be to do some tests in the field when the drone has not much battery, to see how it reacts. For example by setting a small mission when battery is already low.
Tomi
Cookie Policy
