Hola, quisiera preguntarles que pasa cuando tengo bateria baja y no ha finalizado el plan de vuelo que tiene el dron?. Este regresa a casa, se cambia la bateria y retoma el vuelo sin finalizar?. Me podria explicar como reacciona la aplicacion.
Gracias
When the battery percentage is below the defined safe behavior, it will automatically return back to the home position(i.e. the location from where the drone was started).
The Pix4Dcapture app is acting as a third-party application so it cannot give instructions that would override the safe behavior of the drone. For more information, I would recommend you to go through the below link.
