Pix4D Capture Return to Home Function issue
Using Pix4D Capture on DJI Mavic 2 Pro with Apple iPad Mini 4. My Return to Home function is sending my drone home with 60% battery life still remaining. I would prefer that the drone return home a 25% battery life remaining but I cannot find a way to adjust this setting. The DJI Go4 ap is currently set to return at 25% battery life. I use this same setup with my DJI Phantom 4 Pro and there is no problem. Does anyone have a solution?
I believe I resolved this issue with a setting change in the DJI controller settings for the Mavic 2 Pro. Under the battery settings, I toggled off the Smart Return Home function. This helped. The drone doesn’t auto return now until remaining batter power falls below 30%. I still desire a software setting in the Pix4SCapture for this type of change.
