Dear
I am using Phanton 2 Vison Plus with Pix4D Capture 1.0.2 (Android).
Why drone always returns to home when battery capacity reaches to 50%?
Thank you!!
BR,
Antonio Hsu
Dear
Thank you!!
BR,
Antonio Hsu
Hi Antonio,
Do you still get this issue with our latest Android version (2.0.8)?
Normally you should get a message alert when the battery reaches 20% and then the drone will automatically return home when the level is critical.
This may not be the case for you, but when I fly a long linear mission along a road, I also get the warning around 55% when I have been constantly traveling away from the initial home point. I assume that the Quad knows it needs to start back home since it must travel nearly the same distance back. I just reset the home point and keep flying (until 20-30% is reached of course) .
