I often use batch processing overnight and have never experienced any issues with it until last night. I am trying to process Micasense Rededge data which is the only variable compared to my normal process.
When I try to execute the batch script I get the following echoed back (this is echoed for each project, I just pasted the last instance though):
E:\KGP NDVI\Pix4D Projects>echo RUNNING PROJECT KB4_KGP_NDVI
E:\KGP NDVI\Pix4D Projects>"C:\Program Files\Pix4Dmapper\pix4dmapper" -c -r "E:\KGP NDVI\Pix4D Projects\KB4_KGP_NDVI.p4d"
[2020.10.20 08:05:09][ 18%RAM][ 0%CPU][Warning]: Warning w9020: GDAL Error <1> PROJ: proj_get_authorities_from_database: Cannot find proj.db
E:\KGP NDVI\Pix4D Projects>echo PROCESSING FINISHED
The instructions in my script for each project are:
echo RUNNING PROJECT WB1_KGP_NDVI
"C:\Program Files\Pix4Dmapper\pix4dmapper.exe" -c -r "E:\KGP NDVI\Pix4D Projects\WB1_KGP_NDVI.p4d"
I’m running version 4.6.1, I can provide machine specs if needed though I feel like that isn’t the issue…
Any feedback would be appreciated
