AutoTag as Check Points
currently you have an amazing feature to autotag GCPs while scanning with the Pix4Dcatch App. It would be very helpful if you could define before uploading to the cloud if a GCP is a GCP or a Check Point, as you can in Pix4Dmatic or Mapper.
The reason for that is: It is quite common to use Check Points in order to check the accuracy of your scan, as a proof for the customer, as you can do with drone data.
This would be an amazing and really helpful feature for proofing accuracy and should be easy to implement, since Pix4Dcloud is already able to process Check Points.
Kind Regards,
Anton Schlei.
Hello Anton,
Thank you for your feedback, we sent this feedback to the developers and in case that they decide to implement this we will contact you as soon as possible.
Again, thank you for your feedback.
Kind regards
