[Android] Overlap percent needs more choices
I did a flight with P4D on 90% overlap, and got 700 photos. Then I created same mission with 80% overlap and it was like 1/2 the photo count (or less I recall). It occurred to me that the overlap is both side and front, so a 10% increase on both has a multiplied effect.
On Drone Deploy, we can choose different side and front overlaps, and I am now seeing this is somewhat critical to controlling how many photos I want taken.
Its important enough that it makes P4D second choice for flight control currently. Its too bad, as I like the double grid structure mode of P4D. I’m just surprised we can’t choose increments of say, 1 or 2% for overlap as that affects post processing time and several things.
thanks
Hi James,
For the Android version of Pix4Dcapture, you can basically choose the front overlap with steps of 10%, from 70 to 90%.
However, if you activate the advanced mode (in the menu where you select your type of mission, tap SETTINGS and tick Enable advanced mode ), you will be able to choose the frontal overlap with steps of 5% from 0 to 95%.
Note that the side overlap is automatically calculated to be the closest as possible to the frontal overlap.
For the iOS version of Pix4Dcapture, it is possible to set the front and side overlap separately, with steps of 1%, from 20 to 90%.
Gael, thanks for the explanation. Man, that advanced mode setting is buried. 85% seems about what I wanted.
Normally its easier for the programmers to have same interface for multiple systems, odd that the ios allows 1% increments and separate control for side and front. Do you have two different people doing ios and android and they don’t get along the best?
thx
This is silly. Why have more advanced settings for one os and not the other? When I see the number of pics taken on a particular flight path and then it turns to come back in opposite direction the front overlap is far closer than the side overlap. An easy way to control front overlap should be in the camera angle and speed or how often it snaps a pic then use “overlap” setting for side overlap. Now I have to do test flights to have pics for company to review before doing the actual job. That is not cost or time efficient on anyones part.
