I am using the iOS version of Pix4Dcapture and need higher than 90% overlap.
This is needed because doing roof inspection work, the 90% overlap is for the ground but on a two-story house I only get 75% on the roof. For me, 75% is the low end as my target is closer to 85% so my only option right now is to fly 2 missions slightly moved from one another.
Running the adjustment up to 95% shouldn’t be too hard and I probably wouldn’t go farther than that or the picture count goes up exponentially.
