I’m trying to export a mesh to 3D PDF, but I can’t find any instructions on how. I’m using the latest version of Pix4D and its the pro demo version. I have 14 days left and I need to create some samples for a prospective client.
In the processing options of step 2 you can select the 3D pdf as output for the mesh. If you already processed step 2 you don’t need to process it again. You can simply go to process -> generate 3D mesh to process only the mesh.
Hope it helps!
Thanks Alex! I couldn’t figure out how to export. Pretty unintuitive interface, I must say.
So I did include the 3d pdf in a project I am working on but I don’t understand how to export it? Where is the export function for these?
Thanks.
Hi @shawn,
If you have selected the 3D pdf as output for your mesh:
It will be generated and located in your result folder:
your project/2_densification/3d_mesh/yourproject_simplified_3d_mesh.pdf
Hope this will help.
Best
Thanks Marco,
Lots of instructions on how to make sure that the pdf was being generated and take you 95% of the way to getting to the pdf. Your info there with the path and the button to open the path was the last 5% .
Thanks that makes it clear.
