Can a 3D pdf be generated in the cloud?
I ask because I processed a project on my desktop and ticked the create pdf box and the pdf that was “created” was blank.
TIA
Mark
TIA
Mark
Hi Mark,
to correctly visualize the .pdf file you need to:
Open the 3D PDF with Adobe Reader. To download Adobe Reader click here.
Follow the instructions written in this post https://community.pix4d.com/t/3520-3D-Mesh-in-PDF-is-black.
Cheers
Excellent. Thank you.
Can it be processed in the cloud though?
It can be processed on the Cloud but it cannot be downloaded as an individual result there. To obtain the desired output the following requirements are needed:
I Would like to know if I can smooth my 3d pdf from the pix4d bim processing.
thank you
Hello! I have the same issue. But my PDF remains blank, after I choose trust this PDF always.
Hi @smirnides
May I ask if you have also tried enabling the playing of 3D content in PDF?
To enable 3D content permanently:
You can also try making sure to use the latest version of Adobe reader (from version 11) as well as keep the GPU driver updated.
Sincerely,
Rosana
