Can anyone confirm if it’s possible to support multiple texture files or does it have to be a single texture file?
Also could we please get geo referenced 3d meshes rather than this shifted stuff…
Hi Jeremy,
Welcome back to Pix4D Community! Thank you for your question.
Only one texture file is supported. You can however modify the texture with third-party software.
The 3D Textured Mesh that Pix4Dmapper generates is not georeferenced. It has coordinates in a local coordinate system centered around the project. In the project_name\1_initial\params\ folder, you will find a file called project_name_offset.xyz. This file contains the offset coordinates.
You can find more information about your question in the following articles:
Let me know if you find these articles helpful or if you need further support.
Cheers.
