Missing areas in orthographic when Zenmuse P1 50mm lens is used. However if I selct only photos from the missing areas and re-process they stitch fine. All photos from data set together snd the missing areas appear sgain. Each time I process the missing areas change.
Hi @fly1,
Welcome to the Pix4D Community
In order to provide an answer, we need you to provide some additional information, like the product you are using and some screenshots of the issue.
You can also create a thread in the section dedicated to the product you are using:
Thank you for understanding.
Daniele
