Hi group. I’m just starting out with Pix4D mapper and have run into a snag.
I recently completed a survey and 6 of my camera shots, out of 877, are shown at a goofy angle.
Is there a way to edit the camera angle back to the horizontal?
I know I can disable them and reprocess, but I would like to be able to edit them as well and make them correct.
Very much appreciated.
Sid
Thank you for your message and welcome to the Pix4D Community .
From the image capture you shared, it seems that all the images are taken with nadir orientation. Could you eventually show me the wrong camera orientations from another angle of the rayCloud?
I can see that there are some artifacts in the back of your projects. Please add some Manual Tie Points (MTPs) in this region:
If you are still getting errors after using MTPs, please share with us the Quality Report in pdf format.
If you can’t share the report publicly, feel free to open a support ticket here: https://support.pix4d.com/hc/en-us/requests/new?
I believe I have a similar issue with a rotated ray-cloud. Coordinate systems match, I have 8 GCPS. Quality report uploaded as well. Please help. 100017937_Ortho_report.pdf (421.0 KB)
Thank you for sharing your quality report.
It seems that the images were “rotated” because the GCPs coordinates are incorrect.
Could it be possible to open a support ticket with us where you share about 5 to 10 images (where GCP targets are visible), the GCPs file, and your .p4d file?
Thank you for the additional image. I can see the issue now.
Yes, please try adding some Manual Tie Points (MTPs) and let me know.
If possible, please provide me the quality report, I will then be able to see the settings you used.
