Wild Error in Volume Calculations in Cloud from MAP View
I have uploaded a map with a clear conical dirt pile to PIX4D cloud.  The quality report is excellent and the point cloud is clear.  I have tried to measure the volume in two ways.  First, from the 3D view I trace the base of the pile.  The volume computaion results are as follows:
Area:  3,603 sq ft
Projected Area:  3,572 sq ft (makes sense - slight slope to the base ground)
Volume:  940 cu yards (the pile is about 9 feet high so this is a ballpark reasonable number)
If I then on the same map go to the 2D “MAP” view and use the volume measurement tool there to trace and measure the same pile, I get:
Area:  3,552 sq ft (this is consistent with the above)
Volume:  34,124 cu yards!!!  Not possible - this would correspond to a cylinder about 100 yards tall!
What is going on here?  Same map, same dirt pile.
Here is the map in question:
https://cloud.pix4d.com/pro/project/381446/map?shareToken=01ceb0de-bf0e-4ae8-837d-191c5b189858
Thanks, Mark
Hi Mark,
Thanks for reporting this. We are looking into it an I will update this thread here once we identified what’s causing such a big difference in the calculations.
Mattia
Mark,
We identified the issue and a fix is going to be live early next week.
Have a great weekend,
Mattia
Hi Mark,
It turns out we managed to release a fix quicker than expected so it is already live. Your volumes should now work as expected both in the 2D map and in the 3D model.
Cheers
Hugo Campos
I checked my map and now the computations seem consistent.  Thanks for the QUICK patch - appreciate the excellent support on this.  Mark
