when using nadir and oblique images, which type of processing should I select?
Hi George, I guess you mean if use “aerial nadir” or “aerial oblique or terrestrial”, does not really matter, since the step 3 is blocked when selecting oblique mode, but if you select aerial, the orthomsaic is not very good, so better you process only nadir images for step 3, and both datasets for step 1 and 2 to obtain a good point cloud.
