I got this weird warning message today while processing a project:
"[Processing]: Color balancing [group1]
[Warning]: J:\jenkins\workspace\pix4dmapper_build_depends\label\win\tmp_external\build\ceres\internal\ceres\line_search_direction.cc:86 Restarting non-linear conjugate gradients: 2.53971
[Warning]:
[Processing]: Generate orthomosaic [group1]
[Warning]: Projection failed with buffer.isGeo() = yes
The last message goes on for quite some lines.
So my question is two-fold:
Do I need to worry or is it ok to ignore these warnings
The first message which seems to include a path of some kind seems a bit weird. Is this a Pix4D internal developer path? Should it still be in the code?
Thanks in advance
Pix4Dmapper Pro 3.0.13
Also getting the same line:
No clue what could cause this…
This is happening while generating orthophotos, results seems to be fine.
Checked my results.
Unfortunately it’s totally off. While the point cloud and resulting exports seem to be in the right place, the generated world file for georeferencing the orthomosaic seems to be wrong.
In my case the orthomosaic geoposition is off by 100km or so when inserted into Autocad
Pix4D Team, please advise.
P.S. For now, I will assume that the main cause is the recent update to version 3.0.13. As a quick fix, I will uninstall and rollback to version 2 which had no issues for me. Nevertheless, please take care of this. Thank you.
Hello Florian,
Could you please send us your full log file, quality report and orthomosaic : support@pix4d.com.
Best Regards,
I am also seeing this warning:
[2016.11.01 13:08:04][43%RAM][ 0%CPU][Warning]: Projection failed with buffer.isGeo() = yes
[2016.11.01 13:08:13][39%RAM][22%CPU][Info]: Generate orthomosaic [group1] [1/63] elapsed 10s:523ms …
[2016.11.01 13:08:14][43%RAM][22%CPU][Warning]: Projection failed with buffer.isGeo() = yes
[2016.11.01 13:08:23][42%RAM][29%CPU][Info]: Generate orthomosaic [group1] [2/63] elapsed 20s:671ms …
[2016.11.01 13:15:44][23%RAM][12%CPU][Info]: Generate orthomosaic [group1] [3/63] elapsed 07m:41s:361ms …
[2016.11.01 13:23:12][23%RAM][15%CPU][Warning]: Projection failed with buffer.isGeo() = yes
[2016.11.01 13:23:20][18%RAM][19%CPU][Info]: Generate orthomosaic [group1] [4/63] elapsed 15m:17s:439ms …
Is there any additional information related to the cause?
We are also getting this warning in 3.0.13.
Hi Jason and Anthony,
Could you please write a request to Support and attach the following:
- The quality report: …\Project_name\1_initial\report\Project_name_report.pdf
- The project log file: …\Project_name\Project_name.txt
- The .p4d file: …\Project_name.pd4
Please also provide:
- Version of Pix4D desktop downloaded and with which you have the problem.
- PC operating system.
- PC configuration: Amount of RAM memory, GPU used and driver version, CPU used, available hard disk space.
Pix4D support request form: https://support.pix4d.com/hc/en-us/articles/hc/en-us/requests/new
Has there been any development into this error message?
I understand looking into a case by case basis, but if the answer can help more than just one person please post it on here as well.
Thank you
I am still getting the message, but it doesn’t seem to be hurting anything… I haven’t heard anything back from Support.
I get those error messages also :(
Hello All,
This warning “Projection failed with buffer.isGeo() = yes” is an internal warning that should not worry you. In fact, we have removed it from the log file in version 3.1. to avoid confusion.
Thanks for the info Pix4D!
