projectVIS failed
Just curious about what this error means.  Project is a 400 photo ortho/topo with GCP.  No other errors were encountered.  The outputs from processing all look good.  This error appears in the log near the end of the process
you can ignore this message. It is a warning (not an error message). It could be useful in case if the project failed during some steps.
I just had every photo come up with the same error/warning as the ortho was being processed. The computer was running at 85%CPU which never happens. It took over 21 hours to do the ortho and once it was complete the ortho was the same photo in every position on the entire site which should have been 832 different photos.
To investigate your issue we would need more details about your project to provide assistance in the most efficient way. Could you please contact the Support Team and also send us the following:
▸ The quality report (.pdf format): …\project_name\1_initial\report\project_name_report.pdf
▸ The project file (.p4d): …\project_name.p4d
▸ Description of the steps before receiving the error.
▸ Screenshots of the main problems with the software/outputs
Additionally, you can also attach to the message the machine specs of your computer:
  1. Click the Windows Start icon and type System Information. Select the application in the list above.
  2. In the application, click File > Save… and export the content.
  3. Attach the file your_file.nfo to the reply.
Thanks!
