Hi all
I just used the magic tool in order to prepare a prescription for a spotspray Green on Green.
First we did a drone map with the weeds visible as shown in the screenshot.
From the drone map we used the Magic tool in order to select all the weeds. The tool works perfectly.
After that we downloaded the shapefile of the areas created by the magic tool and with that we created the prescription with Qgis.
I hope this helps
Best
Filippo
Hi Filippo,
Thanks for sharing, that looks great! And you will love our new release!
Would you be able to share this dataset with us?
Yes sure…let me know what I have to do…
Filippo,
We shared a Google Drive link to your email, please upload the projects there, the raw images are always helpful.
best
José
Hi Jose,
did you receive the data? Here you can see what the sprayer did.
Yes, data received! Thanks for sharing.
Wow, that looks good. Was the application successful?
I will send an email to follow up on this.
Yes the application was good, we modified only the delay of the sprayer because was not centered.
That was the only thing, the sprayer and the Mavic 3M use the same RTK base.
