hello,
We are trying to refill holes of the triangle mesh with the new metod of the version 2.2 .We have followed the tutorial of Julia jesse but when we put to generate 3D mesh the programme create biger holes. We don’t know what we are doing wrong.
Thank you for your time
Dear Adria,
It is important to make sure that the surface is oriented correctly: the normal should be pointing outwards when using the right hand rule.
Otherwise, it could also be that there are not enough 3D points in this region. You can for example reduce the Minimum number of matches to 2
https://support.pix4d.com/hc/en-us/articles/202557799
Be aware however that this risks increasing the noise in other regions of the project.
Best regards
