Warning w9020: GDAL Error <3> Free disk space available is 657153675264 bytes, whereas 2015934081744 are at least necessary. You can disable this check by defining the CHECK_DISK_FREE_SPACE configuration option to FALSE.
Hello Edall Systems,
Thank you for sharing this information with our community.
Usually, this is a warning that there is no adequate storage space on the hard drive to complete the file generation. Did you maybe encounter cases that the warning was not valid?
I am seeing this message and have more than adequate disk space. Where do I check the option to false?
Hi Clifton,
You can largely ignore these warnings. Unless it is an error message, it shouldn’t impact your outputs.
