Volume report Incorrect Elevations
When I generate my volume reports the maximum Elevation does not match up with the elevation on the top of the stock pile. Is this the max elevation at the bottom of the stock pile? Has anyone else had this issue?
Hi @jex ,
First and foremost, sorry for the late reply.
I shared your question with the team and the “maximum elevation” that you see in the Propertis panel when you select the volume is referring to the base polygon. It does not refer to the Volume’s height and that is why it’s not matching with the elevation of the marker.
I understand that this might be confusing for the user so, as the UX designer, I’ll try to improve how the information is displayed here. Let me know if this was helpful or if you need any further assistance.
Diana
