Hi everyone,
I’m currently using Pix4D Mapper to compute stockpiles volumes in a quarry. I can create the volumes alright, but sometime i need to refine the contour of the stockpile i marked. To do that i click my volume then drag the vertex were i need. The problem is that when i move a vertex, the program freezes for several seconds (almost 1 minute for big stockpiles) before i can click anywhere else. So it takes a very long time just to adjust the stockpile contours (even-though the volume has not been computed already). This is very annoying.
Is this a normal behaviour ?
I had to do the same job last year and i didn’t encounter this issue on the lower Pix4D Mapper version at the time. I’m currently using V4.6.3
Thank you,
