Hi everyone,
I’ve been using a DJI Mavic 3 Multispectral for a while, and I’ve noticed this issue only when surveying vineyard fields.
As you can see in the picture, the multispectral images show some kind of glitch, bad stitching, or artifact along most of the vineyard rows. As a result, the vegetation indices also contain the same shadows/artifacts, making it difficult to understand whether it’s a real issue in the field or just an image processing problem.
What is strange is that the RGB orthophotos do not show the same problem and are processed correctly without these artifacts.
Has anyone experienced the same issue?
I also tried processing a single band only, such as the NIR band, but the glitch is still present. Sometimes it appears in different parts of the vineyard, but I can still find many of these artifacts.
