Vertical drone route map using PIX4D software
Is it possible to use PIX4D software to map the drone route to take images from the surface of a wall? Note overlap and distance between the drone and the wall should maintain constant numbers.
Thank you!
Hello @agolrokh, PIX4Dcapture can’t do vertical mission. However, you should be able to do the vertical mission using our PIX4Dscan app if the drone you are using is supported. For more information on supported drones and cameras visit,
