Hi Everyone
I have a copy of trial and is trying out the workflowof processing the UAV images to generate the point cloud, 3D mesh model and Ortho mosaic for loading into Orbit GT software for viewing.
I managed to get the point cloud and mesh generated and georeferenced using ground control points however, when i export the image geolocation and orientation parameters as txt file for loading into Orbit, the image position is not located at the right position.
Is there anyway I can post process the GPS position (i have GPS base data for correcting) or I can translate the image with some factor so that the exported parameters will be with the correct position.
Eric
