TIN geration
I want to end up with the best possible TIN. To achive that I will use terrain layers as breaklines.
My question is:
Can I import polylines, defined as a terrain layer, with vertices NOT based on the point cloud but on RTK-measurements in the field ?
regards
Tibor Vári
Hello tibor.vari
The answer is Yes, You can import a dxf file with your polylines (RTK measurements) and select the new layers as breaklines.
Your polylines will be used as a breaklines and the TIN will use their vertices.
All the best!
Rafel
