I have a problem. When I try to create a new mission in an area totally different from the last zone flown, when trying to program the new flight grid (add a mission), the flight plan of the last mission carried out always appears. I have uploaded a KML thinking that with that it would be solved, but it does not happen like that. The KML opens without problems but when I try to plan the flight on the KML, the default grid always returns to the area of the previous flight. It is very frustrating to be in the field and have to “drag” the default grid from one area to another, especially if they are hundreds of km between them. That could be happening? Thanks a lot
Hi Raul,
Which version of Pix4Dcapture and firmware are you using?
