Tetracam RGB+3 band definitions
In tetracam tutorial (https://support.pix4d.com/hc/en-us/articles/202560219-How-to-create-and-process-a-Tetracam-dataset#gsc.tab=0) the camera band definitions are said to be taken by MCA file of the camera. However pix4d does not ask for the MCA file after adding images. Also I cannot set the band information by editing the camera model. The drop down menu only shows RGB. Can you help me in defininig the 6 bands of the images correctly. I attach some screenshots of the menus.
Hi Elcin,
We were able to reproduce this issue: the images are recognized as 3 bands instead of 6. We have opened a bug report for our developers. Thanks for bringing up the problem.
Cheers
Has any progress been made on this issue as I am experiencing the same issue when importing multi page TIFFs from a MicroMCA6
Hi Nik,
The problem has been identified by the developers and the way the information from the bands is read should be improved. Updates will be posted here if it gets fixed.
I am having the same issue with an MCA-4. this needs to be fixed ASAP!
We would need a *.mca image file from the Tetracam RGB+3 camera to continue fixing the issue.
This will help us understand how Tetracam saves the RGB information in the .mca, so that we can correctly read it.
Could an owner of that camera send us such files through a support request? Please mention that it is related to this Forum post.
A few improvements were made already for Tetracam cameras to improve the reading of the images and the camera model, these will be released in the next 3.3 Preview. However, to continue improving the compatibility, we would need the file above. Thanks for your help.
I have just uploaded a sample image as requested - that is 7 individual images (6 bands plus the ILS) and one multi-page TIF of the 6 bands processed using PixelWrench and your suggested workflow for processing Tetracam data.
Here is also an extract from some correspondence from Tetracam on the image format I had in the past:
"When you open a 10 bit RAW or DCM image in PW2 it is presented on screen as a 24 bit image (due to limitations of the Microsoft GDI+ display environment).
24 bits = 3 bitplanes of 8 bits each. To preserve 1024 levels of data we encode into 24 bit space;
1. Modulo division of input pixel value by 4, keep the remainder.
2. Write the quotient to the green and red bitplanes.
3. Write (quotient – remainder) to the blue bitplane.
This displays the image as monochrome with a maximum difference on the blue bitplane of –3.
To extract the original 10 bit input from this scheme;
1. Read green value.
2. Read blue value and subtract from green (results in 0 to 3)
3. Multiply green x 4 and add the difference (from above).
The pixel ordering of an RGB image is b-g-r so you need to tell your output program how to interpret what it’s reading. If you are able to get RGB samples directly then just perform the math above to reconstruct to 10 bit."
In the past, I have separately processed the imagery an additional step (as above) to a 10-bit monochrome TIF across the 6 bands (actually saved as 16-bit) bit format to process in the SfM software we were using at that time…but I am hoping you can solve this to allow direct import of the imagery and allow us to utilise the full colour depth of 10-bit data.
Cheers for your attention on this issue :slight_smile:
Thanks for the files and information Nik!
We’ve transferred it to the responsible developer. We will post here if we have any updates.
The way the camera model for Tetracam cameras is read should be improved in the next Preview version that will be released here: https://cloud.pix4d.com/download/
We would need an *.mca file of a TetracamRGB+3 project to further improve the compatibility of this camera.
If you have one, please send it through a support request mentioning this forum post: https://support.pix4d.com/hc/en-us/articles/hc/en-us/requests/new?
Thanks!
The new Preview 3.3.13 is out with the update. More here: https://support.pix4d.com/hc/en-us/articles/115002250683
Still looking for the *.mca file to further improve the Tetracam support.
I will send the MCA File from the tetracam mca6
Because the problem is not solved  there is till no rig with 6 camera.
best regards
Cor kardux
This new revision has not fixed the problem. The program now asks for the .mca file, but does not bring up multiple cameras as shown in your documentation. I still get an Tetracam RGB sensor that can’t be edited to add four bands. How can I send you my .mca?
I just send this afternoon a MCA file from my Tetracam MCA 6 to support…im glad i’m not the only one that have this problem…
Here’s a few screen shots. Loading images, reading EXIF files. Next screen asking for .mca file. Next screen after .mca was loaded showing Tatracam RGB+3 sensor loaded. I can edit the camera model, but won’t let me add the right sensor(s) with the proper four bands.
Not working.
Hi everyone,
I am having exactly the same problema as Paul and Cor. I cannot access the camera model of my micro MCA for setting up the right band.
I really need this to be fixed asap as there are several projects I need to finish.
@Luis
Is it possible for you to share with us the dataset along with the MCA file so we could test it from our side?
Ina
Ina, any progress on this issue? I sent you my .MCA file along with with one of the projects we are trying to modell? It seems you do not have download any of the file from We Transfer?
Cheers
Luis
I sent a complete data set, with geolocation and .mca files about a week ago. I too am very eager to see a solution.
But have a good weekend anyway!
P-
Just tried the new release. It doesn’t appear anything has changed and still can not recognize the MCA-4 multipage TIFs.
dissapointed…
Hi Paul, Cor and Luis,
Could you please update to the latest stable version and try to process your dataset?
For more information please check the new article on how to process tetracam imagery:
https://support.pix4d.com/hc/en-us/articles/115005187543#gsc.tab=0
Ina
