After I start Pix4D Cature app, then press the start button then switch to F position, then press next .
In the Drone connection window i have a test message Connected to range extender Wi-Fi and the next button will not work.
Please help
Please help
Need lot of time, but probably you will find the solution.
I have the exact same issue…cant get past the Connected to Range Extender WiFi. I am using teh beta with Inspire 1 Pro/Zenmuse X5…
Hi all,
This issue should be solved by now.
We have just officially released the iOS Pix4Dcapture 1.0.0!
Here is the corresponding forum post: https://community.pix4d.com/t/4968
You will find details about the procedure if needed.
