Support for Pix4D crashing
Hey,
I wanted some help. I have the following system configuration (i7-7980 XE, 128GB ram, 1 tb SSD, titan Xp). I am trying to generate a 3D model with 8086 images taken using the standard camera on multiple DJI Phantom 4 drones. I have my images loaded in Pix4D and i am running the 3D model present. Initial processing is set to full, Point Cloud and Mesh settings are - image scale = 1, point density = high, min matches = 3, Multiscale = off, i am not exporting point cloud, Mesh settings are: High resolution and im exporting Fbx.
My pix4D randomly crashes in the first step. I have set the RAM so that only 120 GB is used and have reduced core to 34 instead of 36. I have also disabled GPU.
Could you help me please with this. Let me know if you need any more info.
I also wanted to ask that i am processing a very large image dataset for my company next. They will be about 20 - 30 thousand images. We are creating a 3D model for an entire gold course. In order to do that we have ordered a new system with the following specs:
intel Xeon latest (dual cpu (20 cores 40 threads = 80 threads)
128 gb ECC memory
quadro P5000
2 x 2tb SSD
I wanted to know if this system is enough to process 20 - 30 K images. I dont mind it taking alot of time. I just dont want it to crash. Please help. Images will be fro DJI phantom 4 drones with standard camera.
Thanks in advance for the help. My company is planning to purchase a solution from you and i am currently running a trial version to test it for our use case.
Hi Ali,
Can I ask you to submit a request to Pix4D Support Team? We’ll investigate the issue which you’re experiencing and talk about your hardware resources for your next project. Don’t forget to send us the following:
  • The project log file (text file): …\project_name\project_name.log
  • The project file (.p4d): …\project_name.p4d
  • Machine specs:
  1. Click the Windows Start icon and type System Information. Select the application in the list above.
  2. In the application, click File > Save… and export the content.
  3. Attach the file your_file.nfo to the reply.
As a side note: Have you meant i9-7980?
Generally, what we are advising in terms of processing large datasets is to:
For example:
  1. 8 subprojects will be resulting. (1,2,3,4,5,6,7,8)
  2. Afterward, you should process only step 1 in each of them.
  3. Once the 8 subprojects are ready,
  4. Merge 2 by 2.
  5. Then 4 subprojects will be resulting, (a,b,c,d)
  6. You can use 2 computers and on each merge 2 subprojects (a-b resulting A , c-d resulting B )
  7. Then you will obtain A and B and use just one computer, merge them and process steps 2 and 3.
Thank you
