I am processing about 60 flights of 80 fields… I decided to group several fields into single flights to simplify the boundary and gain some flight efficiency. I have created a master project for the flight, and now wish to copy it into multiple instances, each for a separate field so I can do the boundary trim of the Ortho mosaic to just that field.
Is there a way to save this main file several times, so I can do keep the orthomosaic and then trim to just the field boundary?
Or… should I export the Orthomosaic and import it as a tiff into each of the individual field projects? If so, is this the preferred workflow? (ie, do I repeat this approach, adding the multispectral processing in the ‘master’ and then exporting / importing into the individual field files?
-Mike
