Is there a way to specify the max amount of RAM to use in Pix4D via command line? I know you can do that with the CPU, but I do not see the option for RAM in the command line tutorial here:
https://support.pix4d.com/hc/en-us/articles/202560329-How-to-use-the-command-line
Anyone know if this can be done?
Hi Adriano,
Pix4D doesn’t have built-in RAM controls for the command line as other systems typically have handled it better than Pix4D has in the past. Typically a command line environment will be containerized in a system such as Docker that has that sort of configuration already built-in.
Free options such as these from Docker are superior to what we can provide so we haven’t put resources into building that out. Comparable solutions have their own implementations but they’re generally in line with the toolset Docker provides.
