"Save As"
Should “Save As” take about an hour on 2600 pix project?
Hi Dennis,
It depends on what you are trying to save. If you “save as” a non-processed project, it should take few seconds. If you try to “save as” a project that has been processed and has many outputs, then it could take some hours.
Hope it helps!
Cheers!
Got it.
I was trying to save as, so I can process several tiles of the same project at the same time. The “save as” time - pretty much killed that work around ((
By the way Pix4d is performing really well when several pix4d projects running at the same time. My record is simultaneously processing 6 pix4d files (each +/- 300 pix). Very convenient for over night
