I received a set of drone images of a roadway without metadata. When I processed the data the point cloud is rotated 90 degrees about two axis. This is a problem because the orthomosaic is not looking straight down at the roadway. Is there a way to easily rotate the entire point cloud project 90 degrees about each axis? When I try and put in an ortho constraint of 90 degrees within the raycloud it limits me to 20 degrees.
Thanks!
John
