Rotate camera after Initial Processing
I tag the photos after PPK processing and the photos change their location to under Tie Points. How can I make the photos to be on it?
You can download the raw data by using link below:
Link:
https://wetransfer.com/downloads/7439157a63eafa6950ba8e609e3f3c2820181116071626/655b85b7f32e629b6d48e5c80fcd88e320181116071626/faa1c9
https://wetransfer.com/downloads/1c36fc65d8d74054d6bb0e2a2b0a22b820181116071637/cdb4df4bf302df181cb6d66588c6f5ff20181116071637/c23981
I would appreciate if you could help me. Thanks in advance.
Kind Regards,
Namig Osmanov
Hello Namig,
What is the calibration method you are using?
I would use either the “alternative” or “accurate geolocation and orientation” pipeline.
Have you changed the accuracy of the geotags to a few centimeters as it is expected when using PPK?
Thank you very much.
Regards.
