Hi, I got RMSE error in Mapper, but, NOT in Matic. It made sense as there are No calculated Values to compare against. Why is Mapper even giving Absolute Geo Location Variance and Relative Location Variance? Variance against what??? What’s the logic behind RMSE? How do i interpret this?
General information about Absolute and Relative accuracy can be found in this article .
Here is some information that you could find helpful about absolute and relative geolocation in the Quality Report:
Absolute Geolocation Variance
(from here )
This table displays the percentage of geolocated and calibrated images with a geolocation error in X,Y,Z within a predefined error interval. There are ten predefined intervals between -1.5 and 1.5 times the maximum accuracy Amax of all images. If the percentage of images with an error lower than -1.5 × Amax or higher than 1.5 × Amax is big, the Accuracy values might not have been set correctly. Verify if the Accuracy of the image geolocation and the GCPs need to be adjusted.
This table also evaluates the quality of the image geolocation. A high percentage of images with a high error may indicate:
- Noise in the GPS device.
- Poor synchronization between the GPS device and the camera.
- Errors in the geotagging process.
More information about the specifications of this table can be found in this article .
Relative Geolocation Variance
(from here )
This table displays the percentage of geolocated and calibrated images with a Relative Geolocation Error between -1 and 1, -2 and 2 and -3 and 3. A high percentage of images with a Relative Geolocation Error lower than -3 or higher than 3 may indicate an incorrect value for the Accuracy of the image geolocation (given by the user). Verify if the Accuracy of the image geolocation and the GCPs need to be adapted.
In projects without GCPs:
- If less than 99.6% of the geolocated and calibrated images have an error between -3 and 3, then the geolocation Accuracy might be overestimated. Try to increase the value of the geolocation Accuracy.
More information about this table’s specifications can be found in this article .
