The MATRICE 200 uses one camera and the 210 uses two cameras. The 200 is exactly in the center of the camera. But 210 is in a different position.
Does this affect the results?
Or is there an option to show the camera’s location?
There is no option that shows the camera position. The camera position shouldn’t be any issue, only thing you need to take care is that your are getting proper overlap during the image acquisition when you are using two different cameras at the same time.
