Sir I have a project of GSD 2cm. I want to resample the project at 5cm GSD. After completing 2nd process I tried putting value 5 in resolution option in DSM and orthomosaic tab. But after completing 3rd process I am getting the same GSD value which I got in initial process. Sir please give some solution for this problem.
Hi Sanket,
The GSD in the summary will remain the same as it is the average GSD of the single images. However, if you see down in the processing options, you will see that the DSM and orthomosaic resolution shows the one that you had set ![]()
Thanks,
Momtanu
