Reprocessing for new outputs deletes old ones
I recently discovered how to import my models into Sketchfab and went back into some old project to generate the .FBX file. I unchecked all of the other outputs in the Processing Options and left only the Step 2, and Generate 3D Textured Mesh checked.  When the processing completed I had my FBX file, but my LAS file, DSM, Orthomosaic etc that I had generated previously were all gone from the project folder.
Is this intentional or am I doing it wrong?
It is intentional for running the “Steps”, specifically in Step 2 it always makes a new point cloud and thus ALL outputs are wiped out.  If you simply used the pull-down menu to Generate 3D Mesh then the other outputs would not have been deleted.
Thank you Adam!
Glad to help Tim…I have been there and done that, accidentally :)
