I’m trying to remove points representing the stacker belt from over a portion of a stockpile. I can remove the densified points but the volume calculator keeps using the automatic tie points, which I can’t seem to edit out. Will I have to do this using third-party software?
Hi there Bill
You need to run the step 3 again after removing points from densified point cloud. ATP’s won’t affect volume calculations. Volume calculation is based on DSM.
https://support.pix4d.com/hc/en-us/articles/209544746-How-to-update-a-Volume-after-editing-the-Point-Cloud#gsc.tab=0
